The Deluxe Pack: ex return event is live, and yeah, it's got that "one more pack" energy. You see the shake, your heart jumps, and suddenly you're picturing Charizard ex or Mewtwo ex sliding into your deck like it owns the place. Before you start tapping like a maniac, it helps to set yourself up with the right basics—keeping an eye on how you're spending, what you actually need, and even where you're topping up resources. I've been checking Items card Pokemon when I'm planning what to grab so I'm not scrambling mid-event and making dumb choices under pressure.
Don't Let Hype Spend Your Coins
The quickest way to regret this event is opening packs the moment you can afford them. It feels good for about ten seconds. Then you look at your coin count and realize you've basically paid for a pile of duplicates. I try to split my coins into two buckets: a daily limit I'm allowed to burn, and a saved chunk for a bigger run when I've got time to actually pay attention. Because if you're opening while distracted—on the bus, half-watching a show—you'll miss patterns and you'll keep chasing the same EX you've already pulled twice.
Track Your Targets Like You Mean It
People say "use the tracker," but most folks don't really use it. They glance at it, shrug, then keep ripping packs. Try doing it properly for a week and you'll notice the difference. Write down the EX cards you're still missing and the ones you're sick of seeing. Keep it simple. You don't need a spreadsheet, just a short list you can look at before you open anything. It stops you from tunneling on one flashy pull and forgetting the bigger goal: building something that actually wins games, not just looks nice in the binder.
Daily Bonuses Are Basically Extra Packs
The event bonuses are the quiet MVP. Log in, claim everything, clear the missions, and don't overthink it. Those little rewards stack up fast, and they're usually what carries you into a final pack at the end of the day. Plenty of my best pulls have come from "free" attempts I wouldn't have had otherwise. If you're short on time, do the easiest tasks first, then circle back. Missing a day hurts more than missing a single pack.
When to Push and When to Walk Away
There's always that moment: you see a gold glow, you hold your breath, and it's another duplicate. It stings, but that's part of the loop. The trick is knowing when to stop for the night instead of tilt-opening until you're broke. If you want to stay competitive, focus on what improves your deck right now, not what looks legendary on the pull screen. And if you do decide to top up coins or grab extra items to keep your momentum, it's worth using a reliable shop like rsvsr so you can get what you need fast and get back to playing without the hassle.
